Saltar al contenido principal
Brother PT-110 Print Roller Lever Replacement
Qué necesitas
  1. Brother PT-110 Print Roller Lever Replacement, Batteries: paso 1, imagen 1 de 2 Brother PT-110 Print Roller Lever Replacement, Batteries: paso 1, imagen 2 de 2
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Print Roller Lever Replacement: paso 2, imagen 1 de 1
    • Remove the batteries.
  3. Brother PT-110 Print Roller Lever Replacement, Back Plate: paso 3, imagen 1 de 2 Brother PT-110 Print Roller Lever Replacement, Back Plate: paso 3, imagen 2 de 2
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Print Roller Lever Replacement: paso 4, imagen 1 de 1
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Print Roller Lever Replacement: paso 5, imagen 1 de 1
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Print Roller Lever Replacement: paso 6, imagen 1 de 1
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Print Roller Lever Replacement: paso 7, imagen 1 de 2 Brother PT-110 Print Roller Lever Replacement: paso 7, imagen 2 de 2
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Print Roller Lever Replacement: paso 8, imagen 1 de 3 Brother PT-110 Print Roller Lever Replacement: paso 8, imagen 2 de 3 Brother PT-110 Print Roller Lever Replacement: paso 8, imagen 3 de 3
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Print Roller Lever Replacement, Print Roller Lever: paso 9, imagen 1 de 1
    • Using the metal spudger, swivel the pin so that the print roller lever loosens.
  10. Brother PT-110 Print Roller Lever Replacement: paso 10, imagen 1 de 1
    • Gently pull the print roller lever out.
Conclusión
2 personas más completaron esta guía.
Equipo
IUPUI, Team 1-1, Harley Fall 2016 Miembro de IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 Miembros
7 Guías creadas
5 comentarios
Hi everybody ,does anyone knows were I can by such a lever ?
TBH
Daniel Verkest - Contestar
BONJOUR, (I’m French)
Same question: does anyone knows were I can by such a lever ?
Pegase M - Contestar
Did anyone find a source for this part?
Erik Carlson - Contestar
Unfortunately very discontinued. Until someone adds it to thingverse there's not much that can be done.
UN8026001 ROLLER HOLDER ASSY PT100/110
UN8031001 ROLLER HOLDER SPRING PT100
UN8032000 ROLLER RELEASE LEVER PT100/110
Michael Krieger - Contestar
I can fix these by using plastic weld to rebuild the edging. I was totally successful.
George Pede - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 25
Todo El Tiempo: 1,665
