Saltar al contenido principal
Introducción
This guide will show you how to take apart the back panel to replace the keypad contacts.
Partes
No se especificaron partes.
  1. Push on the side of the cover, and remove it. Push on the side of the cover, and remove it.
    • Push on the side of the cover, and remove it.
  2. Remove the batteries.
    • Remove the batteries.
  3. Unscrew the two 9 mm Phillips #1 screws from the top and bottom. Total: 2 x Screws
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. First: To separate the top cover from the body, insert a spudger between the two halves.
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Kits de Reparación de Android
    Estás a un kit de tu nueva pantalla o batería.
    Comprar Ahora
    Comprar Ahora
  6. Gently separate the two covers, ensuring wires are not taut.
    • Gently separate the two covers, ensuring wires are not taut.
  7. Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  8. Carefully pinch the top of the connector. Pull perpendicular to the device until the wire is disconnected.
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  9. Unscrew the three 9 mm Phillips #1 screws shown. Total: 3 x Screws Total: 3 x Screws
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  10. Unscrew both 6 mm Phillips #1 screws from the circuit board. Total screws: 2
    • Unscrew both 6 mm Phillips #1 screws from the circuit board.
    • Total screws: 2
  11. Gently lift the circuit board out.
    • Gently lift the circuit board out.
  12. Peel the keypad contacts up from the plastic casing.
    • Peel the keypad contacts up from the plastic casing.
Conclusión
Kimberly Larsen
Miembro Desde 28/09/16
171 Reputación
5 Guías creadas
Equipo
IUPUI, Team 1-1, Harley Fall 2016 Miembro de IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
Todo El Tiempo: 118
