Saltar al contenido principal
Brother PT-1010 Keyboard Replacement
Qué necesitas
  1. Brother PT-1010 Keyboard Replacement, Remove Back Cover: paso 1, imagen 1 de 1
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-1010 Keyboard Replacement: paso 2, imagen 1 de 1
    • Remove batteries, cassette tape, and cutter blade.
  3. Brother PT-1010 Keyboard Replacement, Remove Screws: paso 3, imagen 1 de 1
    • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
  4. Brother PT-1010 Keyboard Replacement, Separate Device: paso 4, imagen 1 de 1
    • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
  5. Brother PT-1010 Keyboard Replacement, Remove side panels: paso 5, imagen 1 de 1
    • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
  6. Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: paso 6, imagen 1 de 3 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: paso 6, imagen 2 de 3 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: paso 6, imagen 3 de 3
    • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
  7. Brother PT-1010 Keyboard Replacement, Remove Screws from Circuit Board: paso 7, imagen 1 de 1
    • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
  8. Brother PT-1010 Keyboard Replacement, Remove Circuit Board: paso 8, imagen 1 de 1
    • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
    • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
  9. Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: paso 9, imagen 1 de 3 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: paso 9, imagen 2 de 3 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: paso 9, imagen 3 de 3
    • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
Conclusión
Haley Sweet
Miembro Desde 10/30/14
460 Reputación
4 Guías creadas
Equipo
Baylor, Team 4-4, Williams Fall 2014 Miembro de Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Miembros
4 Guías creadas
3 comentarios
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Maria Bitterli - Contestar
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Sincere Cavalier - Contestar
Screen is dull, what to do
Judy Baranczyk - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 37
Todo El Tiempo: 3,035
