Saltar al contenido principal
Brother PT-1010 Cassette Tape Replacement
Qué necesitas
  1. Brother PT-1010 Cassette Tape Replacement, Remove Back Cover: paso 1, imagen 1 de 1
    • Remove the back cover of the device by simultaneously pressing down on the indication arrows on the top center, then pulling toward you.
  2. Brother PT-1010 Cassette Tape Replacement, Insert Tape Cassette: paso 2, imagen 1 de 1
    • Brother TZ tape is required for this replacement process. We don't have the tape cassette but you should be able to insert tape cassette into the red marked area as shown in the picture.
    • Insert tape cassette into the red marked area as shown in the picture.
    • Make sure the cassette snaps into place by applying a small amount of pressure.
Conclusión
Haley Sweet
Miembro Desde 10/30/14
460 Reputación
4 Guías creadas
Equipo
Baylor, Team 4-4, Williams Fall 2014 Miembro de Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Miembros
4 Guías creadas
3 comentarios
So if you've replaced the cassette and it still won't print now what??
Sara Mullaney - Contestar
This was supposed to help with model PT-450D which looks nothing like this. Please help. I can’t REMOVE / replace the cassette !!! It is STUCK inside the label printer!
af4k - Contestar
I have a PT-1880 model and replaced the cassette, but whenever I type something to label something, the label comes out blank. Can someone help me on this? I’ve been needing help on this for a while now.
Yael Rzoque - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 22
Todo El Tiempo: 3,268
