Saltar al contenido principal
Brother MFC-490CW Wireless module Replacement
Qué necesitas
  1. Brother MFC-490CW Wireless module Replacement, Remove screws holding the front panel: paso 1, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: paso 2, imagen 1 de 3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: paso 2, imagen 2 de 3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: paso 2, imagen 3 de 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Wireless module Replacement, Remove the screw: paso 3, imagen 1 de 1
    • Unscrew the 14.1mm screw located at the left side of the device.
    • Unscrew the 12.1mm screw to the right of the 14.1mm screw.
  4. Brother MFC-490CW Wireless module Replacement: paso 4, imagen 1 de 3 Brother MFC-490CW Wireless module Replacement: paso 4, imagen 2 de 3 Brother MFC-490CW Wireless module Replacement: paso 4, imagen 3 de 3
    • Pry open the left front panel away from the printer
    • Be careful. The panel is attached with a data cable.
  5. Brother MFC-490CW Wireless module Replacement: paso 5, imagen 1 de 2 Brother MFC-490CW Wireless module Replacement: paso 5, imagen 2 de 2
    • Carefully unplug the connector attached to the device.
  6. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: paso 6, imagen 1 de 3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: paso 6, imagen 2 de 3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: paso 6, imagen 3 de 3
    • Separate the two clips that hold the module in place.
    • Lift up the module.
Conclusión
To reassemble your wireless module, follow these instructions in reverse order.
Matt
Miembro Desde 10/30/14
64 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-4, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
Miembros de 3
11 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 2,176
