Saltar al contenido principal
Brother MFC-490CW Scanning Glass Replacement
Qué necesitas
  1. Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: paso 1, imagen 1 de 3 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: paso 1, imagen 2 de 3 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: paso 1, imagen 3 de 3
    • Twist green section to allow the scanner head to have a full range of motion.
  2. Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: paso 2, imagen 1 de 3 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: paso 2, imagen 2 de 3 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: paso 2, imagen 3 de 3
    • To remove scanner head, open it halfway as possible and slide the hinges out of place and the head will be removed.
  3. Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: paso 3, imagen 1 de 3 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: paso 3, imagen 2 de 3 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: paso 3, imagen 3 de 3
    • The panels to expose the cords will become exposed when the head is removed.
    • Pull all colored cords from the printer and unscrew the other wire to be fully removed.
    • Pull the black tab from the printer to remove.
  4. Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: paso 4, imagen 1 de 2 Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: paso 4, imagen 2 de 2
    • Once scanner is free from the printer remove all the screws on the bottom base
    • Use a #2 Philips head screw driver to remove the two 12.1mm screws.
  5. Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: paso 5, imagen 1 de 3 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: paso 5, imagen 2 de 3 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: paso 5, imagen 3 de 3
    • To separate the base from the glass hold upright and separate along the edge where you removed the screws.
    • Use hands to expose the glass.
    • Keep track flat once glass is removed as to not lose little parts.
  6. Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: paso 6, imagen 1 de 3 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: paso 6, imagen 2 de 3 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: paso 6, imagen 3 de 3
    • Disconnect the glass from the tracks.
    • Remove old or broken glass.
    • Replace with adhesive tape along the bottom of the header and reassemble.
Conclusión
2 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 4-4, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 57
Todo El Tiempo: 3,696
