Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Many functions, including the LCD screen dial pad and device functions can wear and no longer work and may need to be replaced.
Partes
No se especificaron partes.
  1. Unscrew these three 12.1mm screws holding the control panel in place.
    • Unscrew these three 12.1mm screws holding the control panel in place.
  2. Lift up the front panel from the device. Gently lift up and pull out the data cables that attach the panel to the printer. Gently lift up and pull out the data cables that attach the panel to the printer.
    • Lift up the front panel from the device.
    • Gently lift up and pull out the data cables that attach the panel to the printer.
Conclusión
To reassemble the front panel, follow these instructions in reverse order.
2 personas más completaron esta guía.
Matt
Miembro Desde 30/10/14
64 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-4, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Miembros
5 Guías creadas
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
Raymond Rinaldi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 1,135
