Saltar al contenido principal
Brother MFC-490CW Front Panel Replacement
Qué necesitas
  1. Brother MFC-490CW Front Panel Replacement, Remove screws holding the front panel: paso 1, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: paso 2, imagen 1 de 3 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: paso 2, imagen 2 de 3 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: paso 2, imagen 3 de 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
Conclusión
To reassemble the front panel, follow these instructions in reverse order.
2 personas más completaron esta guía.
Matt
Miembro Desde 10/30/14
64 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-4, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Miembros
8 Guías creadas
Un comentario
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
Raymond Rinaldi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 1,722
