Saltar al contenido principal
Brother CS6000i LCD Screen Replacement
Qué necesitas
  1. Brother CS6000i LCD Screen Replacement, Body: paso 1, imagen 1 de 2 Brother CS6000i LCD Screen Replacement, Body: paso 1, imagen 2 de 2
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i LCD Screen Replacement: paso 2, imagen 1 de 2 Brother CS6000i LCD Screen Replacement: paso 2, imagen 2 de 2
    • Pull the white cover off.
  3. Brother CS6000i LCD Screen Replacement: paso 3, imagen 1 de 2 Brother CS6000i LCD Screen Replacement: paso 3, imagen 2 de 2
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i LCD Screen Replacement: paso 4, imagen 1 de 3 Brother CS6000i LCD Screen Replacement: paso 4, imagen 2 de 3 Brother CS6000i LCD Screen Replacement: paso 4, imagen 3 de 3
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
  5. Brother CS6000i LCD Screen Replacement, LCD Screen: paso 5, imagen 1 de 1
    • Remove the two 10 mm Philips #2 screws that secure the screen.
    • Unplug the ribbon cable located at the top of the circuit board, then gently remove the LCD screen.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cuesta, Team 20-1, Krynen Fall 2024 Miembro de Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
Miembros de 5
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 229
