Saltar al contenido principal
Broil-King BBQ Heat Indicator Replacement Guide
Qué necesitas
  1. Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: paso 1, imagen 1 de 3 Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: paso 1, imagen 2 de 3 Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: paso 1, imagen 3 de 3
    • Gather the tools and parts needed for the repair:
    • Crescent Wrench
    • Scraper
    • Replacement Heat Indicator
    • Be sure that the grill is completely cool and disconnect any gas tanks before beginning the repair.
  2. Broil-King BBQ Heat Indicator Replacement Guide: paso 2, imagen 1 de 2 Broil-King BBQ Heat Indicator Replacement Guide: paso 2, imagen 2 de 2
    • Open the lid and then remove the nut securing the heat indicator.
    • Use a crescent wrench to loosen the nut.
    • Continue to unthread the nut with your fingers.
    • Place the nut in a secure location for later use.
  3. Broil-King BBQ Heat Indicator Replacement Guide: paso 3, imagen 1 de 2 Broil-King BBQ Heat Indicator Replacement Guide: paso 3, imagen 2 de 2
    • Close the lid.
    • Slide the flat edge of the paint scraper under the existing heat indicator plate to pry the plate loose.
    • Lift the plate up, then off of the predrilled holes.
  4. Broil-King BBQ Heat Indicator Replacement Guide: paso 4, imagen 1 de 3 Broil-King BBQ Heat Indicator Replacement Guide: paso 4, imagen 2 de 3 Broil-King BBQ Heat Indicator Replacement Guide: paso 4, imagen 3 de 3
    • Push the heat indicator from the back to remove it from the Broilmate plate.
  5. Broil-King BBQ Heat Indicator Replacement Guide: paso 5, imagen 1 de 3 Broil-King BBQ Heat Indicator Replacement Guide: paso 5, imagen 2 de 3 Broil-King BBQ Heat Indicator Replacement Guide: paso 5, imagen 3 de 3
    • Align the new heat indicator through the front of the plate.
    • Move your thumbs around the plate until the heat indicator is secure.
  6. Broil-King BBQ Heat Indicator Replacement Guide: paso 6, imagen 1 de 3 Broil-King BBQ Heat Indicator Replacement Guide: paso 6, imagen 2 de 3 Broil-King BBQ Heat Indicator Replacement Guide: paso 6, imagen 3 de 3
    • Align the new heat indicator and plate with the factory drilled holes on the face of the BBQ.
    • Hold the plate in place while opening the lid.
  7. Broil-King BBQ Heat Indicator Replacement Guide: paso 7, imagen 1 de 2 Broil-King BBQ Heat Indicator Replacement Guide: paso 7, imagen 2 de 2
    • Retrieve the nut used on the previous heat indicator (remember you put it in a secure location).
    • Thread the nut on the new heat indicator.
    • Use a crescent wrench to finish tightening the nut on the new bolt.
  8. Broil-King BBQ Heat Indicator Replacement Guide: paso 8, imagen 1 de 1
    • Close the lid. You're done!
Conclusión
This simple repair doesn’t take much time, yet is well worth the effort. A working heat indicator provides the necessary information about the temperature to ensure safe food practices, and produce a tasty outcome.
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 36
Todo El Tiempo: 776
