Saltar al contenido principal
Broan-Nutone NU230BL Filter and Light Replacement
Qué necesitas
  1. Broan-Nutone NU230BL Filter and Light Replacement, Filter and Light: paso 1, imagen 1 de 1
    • Make sure the fan switch is centered, and the light switch is set to "off" to avoid any injuries.
  2. Broan-Nutone NU230BL Filter and Light Replacement: paso 2, imagen 1 de 1
    • Squeeze both ends of the bulb cover to pop it out of the slots.
  3. Broan-Nutone NU230BL Filter and Light Replacement: paso 3, imagen 1 de 2 Broan-Nutone NU230BL Filter and Light Replacement: paso 3, imagen 2 de 2
    • Make sure the lightbulb is cool before handling to avoid burns.
    • Unscrew and remove the lightbulb by turning it counterclockwise.
  4. Broan-Nutone NU230BL Filter and Light Replacement: paso 4, imagen 1 de 3 Broan-Nutone NU230BL Filter and Light Replacement: paso 4, imagen 2 de 3 Broan-Nutone NU230BL Filter and Light Replacement: paso 4, imagen 3 de 3
    • Twist the latch above the filter clockwise.
    • Slide the filter out by gently pulling it.
  5. Broan-Nutone NU230BL Filter and Light Replacement: paso 5, imagen 1 de 3 Broan-Nutone NU230BL Filter and Light Replacement: paso 5, imagen 2 de 3 Broan-Nutone NU230BL Filter and Light Replacement: paso 5, imagen 3 de 3
    • Insert the new filter.
    • Rotate the retaining latch counterclockwise to secure the filter.
  6. Broan-Nutone NU230BL Filter and Light Replacement: paso 6, imagen 1 de 2 Broan-Nutone NU230BL Filter and Light Replacement: paso 6, imagen 2 de 2
    • Install the new lightbulb and turn it clockwise.
  7. Broan-Nutone NU230BL Filter and Light Replacement: paso 7, imagen 1 de 2 Broan-Nutone NU230BL Filter and Light Replacement: paso 7, imagen 2 de 2
    • Reinsert the lightbulb cover by pressing both sides and fitting the cover's tabs into the slots.
Conclusión
Your range hood is good-to-go!
Una persona más ha completado esta guía.
Mahdi M
Miembro Desde 01/17/22
169 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 34
Todo El Tiempo: 735
