Saltar al contenido principal
Brightsign 4k Battery Replacement
Qué necesitas
  1. Brightsign 4k Battery Replacement, Outer Shell: paso 1, imagen 1 de 3 Brightsign 4k Battery Replacement, Outer Shell: paso 1, imagen 2 de 3 Brightsign 4k Battery Replacement, Outer Shell: paso 1, imagen 3 de 3
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Brightsign 4k Battery Replacement: paso 2, imagen 1 de 3 Brightsign 4k Battery Replacement: paso 2, imagen 2 de 3 Brightsign 4k Battery Replacement: paso 2, imagen 3 de 3
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. Brightsign 4k Battery Replacement: paso 3, imagen 1 de 3 Brightsign 4k Battery Replacement: paso 3, imagen 2 de 3 Brightsign 4k Battery Replacement: paso 3, imagen 3 de 3
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. Brightsign 4k Battery Replacement: paso 4, imagen 1 de 3 Brightsign 4k Battery Replacement: paso 4, imagen 2 de 3 Brightsign 4k Battery Replacement: paso 4, imagen 3 de 3
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. Brightsign 4k Battery Replacement, Motherboard Removal: paso 5, imagen 1 de 2 Brightsign 4k Battery Replacement, Motherboard Removal: paso 5, imagen 2 de 2
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. Brightsign 4k Battery Replacement: paso 6, imagen 1 de 2 Brightsign 4k Battery Replacement: paso 6, imagen 2 de 2
    • Lift the motherboard out of the casing.
  7. Brightsign 4k Battery Replacement, Battery: paso 7, imagen 1 de 2 Brightsign 4k Battery Replacement, Battery: paso 7, imagen 2 de 2
    • Flip the motherboard over.
    • Desolder the two solder joints and remove the melted solder.
    • Beware of over heating the soldering kit will damage the logic board.
  8. Brightsign 4k Battery Replacement: paso 8, imagen 1 de 3 Brightsign 4k Battery Replacement: paso 8, imagen 2 de 3 Brightsign 4k Battery Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Desoldering Pump
    $3.99
    Comprar
    • Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
    • Pull the battery from the motherboard.
Conclusión
Tuong Ngo
Miembro Desde 02/15/18
85 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S17-G6, Boczar Spring 2018 Miembro de USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 404
