Saltar al contenido principal
Briggs and Stratton 675 Series Spark Plug Replacement
Qué necesitas
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: paso 1, imagen 1 de 2 Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: paso 1, imagen 2 de 2
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: paso 2, imagen 1 de 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: paso 2, imagen 2 de 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: paso 2, imagen 3 de 3
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
Conclusión
6 personas más completaron esta guía.
Equipo
Cal Poly, Team 6-31, Amido Winter 2015 Miembro de Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Miembros
15 Guías creadas
12 comentarios
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Contestar
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Contestar
pinch the front of black cap and pull off
tracy.mullen - Contestar
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - Contestar
Kymberleah - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 72
Ultimos 30 días: 373
Todo El Tiempo: 48,089
