Saltar al contenido principal
Briggs and Stratton 675 Series Repair Air Filter Replacement
Qué necesitas
  1. Briggs and Stratton 675 Series Repair Air Filter Replacement, Air Filter: paso 1, imagen 1 de 1
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
  2. Briggs and Stratton 675 Series Repair Air Filter Replacement: paso 2, imagen 1 de 1
    • Use your hands to pull the air filter case out of the hinge at the bottom.
  3. Briggs and Stratton 675 Series Repair Air Filter Replacement: paso 3, imagen 1 de 1
    • Simply remove the air filter with your hands.
Conclusión
6 personas más completaron esta guía.
Equipo
Cal Poly, Team 6-31, Amido Winter 2015 Miembro de Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Miembros
15 Guías creadas
2 comentarios
Good information, although it didn't resolve my issue. Thanks for sharing
all2thegoodpromo - Contestar
This is a power wash motor water will not come out
hdoggett Doggett - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 38
Ultimos 30 días: 225
Todo El Tiempo: 20,150
