Saltar al contenido principal
Breville JE98XL Juice Fountain Plus Food Pusher Replacement
  1. Breville JE98XL Juice Fountain Plus Food Pusher Replacement, Pulp Basket: paso 1, imagen 1 de 1
    • Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
  2. Breville JE98XL Juice Fountain Plus Food Pusher Replacement: paso 2, imagen 1 de 1
    • Tilt the juicer slightly to the right so the pulp basket is off of your surface.
  3. Breville JE98XL Juice Fountain Plus Food Pusher Replacement: paso 3, imagen 1 de 1
    • Pull the pulp basket down and out from under the juicer cover.
  4. Breville JE98XL Juice Fountain Plus Food Pusher Replacement, Lid: paso 4, imagen 1 de 2 Breville JE98XL Juice Fountain Plus Food Pusher Replacement, Lid: paso 4, imagen 2 de 2
    • Place one hand on either side of the safety locking arm.
    • Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
  5. Breville JE98XL Juice Fountain Plus Food Pusher Replacement: paso 5, imagen 1 de 2 Breville JE98XL Juice Fountain Plus Food Pusher Replacement: paso 5, imagen 2 de 2
    • Firmly grip both sides of the juicer. Twist clock-wise and lift to remove the lid.
  6. Breville JE98XL Juice Fountain Plus Food Pusher Replacement, Food Pusher: paso 6, imagen 1 de 2 Breville JE98XL Juice Fountain Plus Food Pusher Replacement, Food Pusher: paso 6, imagen 2 de 2
    • Place one hand on the food pusher grip, and pull upward. Continue to slide the food pusher until it has fully cleared the food chute.
Conclusión
Madison Burgess
Miembro Desde 10/06/16
499 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 15-1, Livingston Fall 2016 Miembro de Cal Poly, Team 15-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 475
