Introducción
You will be removing and disassembling the stainless steel filter basket for cleaning and/or replacement. To make the process easier, place the juicer in or over the sink before you begin. CAUTION: the filter basket contains small blades to cut fruit and vegetables so avoid contact while handling the filter basket.
Qué necesitas
Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
Place one hand on either side of the safety locking arm.
Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
Twist the filter bowl that surrounds the basket in a counterclockwise fashion. Lift the bowl straight up to remove it from the juicer.
2 comentarios
What are the 3 exact screws for this part? Lost one of the screws when taking apart.
I Twist the filter bowl that surrounds the basket in a counterclockwise fashion. And try Lifting the bowl straight up to remove it from the juicer, but it will not seperate any suggestions?
