Saltar al contenido principal
Breville BKC600XL Water Valve Replacement
Qué necesitas
  1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: paso 1, imagen 1 de 3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: paso 1, imagen 2 de 3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: paso 1, imagen 3 de 3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Water Valve Replacement, "Top" Black Shell Piece: paso 2, imagen 1 de 1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Water Valve Replacement, Silver Casing: paso 3, imagen 1 de 3 Breville BKC600XL Water Valve Replacement, Silver Casing: paso 3, imagen 2 de 3 Breville BKC600XL Water Valve Replacement, Silver Casing: paso 3, imagen 3 de 3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Water Valve Replacement, Water Valve: paso 4, imagen 1 de 1
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
Conclusión
Antonio
Miembro Desde 09/26/12
120 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 1-3, Propen Fall 2012 Miembro de Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Miembros
6 Guías creadas
2 comentarios
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 17
Todo El Tiempo: 5,832
