Introducción
Replacing the On/Off switch should the wiring become faulty.
  1. Use a Phillips #0 screwdriver to remove the following ten screws: Four 18mm Phillips screws. Four 9.75mm Phillips screws.
    • Use a Phillips #0 screwdriver to remove the following ten screws:
      • Four 18mm Phillips screws.
      • Four 9.75mm Phillips screws.
      • Two 8mm Phillips screws.
      • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Remove the two 14.5 Phillips screws. Ensure that only the water inlet valve can be moved.
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Use a Phillips #0 screwdriver to remove the following six screws: Six 14.5mm Phillips screws.
    • Use a Phillips #0 screwdriver to remove the following six screws:
      • Six 14.5mm Phillips screws.
  5. Remove the power cord from the groove. (the black cord that leads into the green wire.) This creates more slack in the wire to give you more room to work with.
      • Remove the power cord from the groove. (the black cord that leads into the green wire.)
      • This creates more slack in the wire to give you more room to work with.
      • DO NOT remove green wire from the cover its attached to.
  6. Carefully pull out the Red and Blue wires that covered at the tip.
    • Carefully pull out the Red and Blue wires that covered at the tip.
    • Do not yank them out from the other end. Move them aside and out of the way.
  7. Carefully remove the On/Off Switch from its slot on the outside cover.
    • Carefully remove the On/Off Switch from its slot on the outside cover.
    • The wires for the switch will need to be tied back to the wires leading to the battery. If necessary, use electrical tape.
Conclusión
Una persona más ha completado esta guía.
Antonio
Miembro Desde 26/09/12
73 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 1-3, Propen Fall 2012 Miembro de Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 24
Todo El Tiempo: 2,313
