Saltar al contenido principal
Breville BKC600XL Heating Tank Replacement
Qué necesitas
  1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: paso 1, imagen 1 de 3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: paso 1, imagen 2 de 3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: paso 1, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: paso 2, imagen 1 de 2 Breville BKC600XL Heating Tank Replacement, Black Water Inlet: paso 2, imagen 2 de 2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: paso 3, imagen 1 de 2 Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: paso 3, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL Heating Tank Replacement, Power Cord: paso 4, imagen 1 de 2 Breville BKC600XL Heating Tank Replacement, Power Cord: paso 4, imagen 2 de 2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL Heating Tank Replacement, Clear Hose: paso 5, imagen 1 de 2 Breville BKC600XL Heating Tank Replacement, Clear Hose: paso 5, imagen 2 de 2
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
  6. Breville BKC600XL Heating Tank Replacement, Heating Tank: paso 6, imagen 1 de 1
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
Conclusión
2 personas más completaron esta guía.
Antonio
Miembro Desde 09/26/12
120 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 1-3, Propen Fall 2012 Miembro de Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 24
Todo El Tiempo: 4,598
