Saltar al contenido principal
Brentwood TS-292B Toasting Lever Replacement
Qué necesitas
  1. Brentwood TS-292B Toasting Lever Replacement, Toasting Lever: paso 1, imagen 1 de 2 Brentwood TS-292B Toasting Lever Replacement, Toasting Lever: paso 1, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove all of the 6mm screws from the bottom of the toaster.
  2. Brentwood TS-292B Toasting Lever Replacement: paso 2, imagen 1 de 3 Brentwood TS-292B Toasting Lever Replacement: paso 2, imagen 2 de 3 Brentwood TS-292B Toasting Lever Replacement: paso 2, imagen 3 de 3
    • Push in the small tab located to the left, and pull the lever tab away from the toaster with force.
    • Remove the toaster cover carefully.
  3. Brentwood TS-292B Toasting Lever Replacement: paso 3, imagen 1 de 1
    • Detach the bundled cable connector by carefully pulling it away from the circuit board.
  4. Brentwood TS-292B Toasting Lever Replacement: paso 4, imagen 1 de 2 Brentwood TS-292B Toasting Lever Replacement: paso 4, imagen 2 de 2
    • Push the tabs in and lift the top of the toaster off.
  5. Brentwood TS-292B Toasting Lever Replacement: paso 5, imagen 1 de 3 Brentwood TS-292B Toasting Lever Replacement: paso 5, imagen 2 de 3 Brentwood TS-292B Toasting Lever Replacement: paso 5, imagen 3 de 3
    • Lift up the tab that is located at the front of the toasting lever.
    • Use tweezers to carefully lift up the metal bar.
    • Remove the springs and replace them with new ones.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 573
