Saltar al contenido principal
Brentwood TS-292B Browning Dial Circuitboard Replacement
Qué necesitas
  1. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: paso 1, imagen 1 de 3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: paso 1, imagen 2 de 3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: paso 1, imagen 3 de 3
    • Remove the five screws indicated using a Philips head screwdriver.
  2. Brentwood TS-292B Browning Dial Circuitboard Replacement: paso 2, imagen 1 de 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: paso 2, imagen 2 de 2
    • Pull hard on the browning lever until it detaches from the toaster.
    • It will take some force to pull it off.
    • Once the tab is off, lift up on the housing to remove it from the toaster.
  3. Brentwood TS-292B Browning Dial Circuitboard Replacement: paso 3, imagen 1 de 1
    • Once the housing has been pulled upwards, carefully uplug the wire connecting the browning dial circuit board to the main circuit board.
  4. Brentwood TS-292B Browning Dial Circuitboard Replacement: paso 4, imagen 1 de 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: paso 4, imagen 2 de 2
    • There are four screws on the circuit board for the browning dial.
    • Unscrew each of them with a Philips head screwdriver to detach the board and remove the board and dial from the toaster housing.
  5. Brentwood TS-292B Browning Dial Circuitboard Replacement: paso 5, imagen 1 de 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: paso 5, imagen 2 de 2
    • There are two holes on the board where the pin from the browning dial can align.
    • Refer to the images if you are having trouble finding them.
    • Replace the browning dial by inserting the pin on the dial into one of the holes indicated.
    • Replace the entire circuit board if need be.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 217
