Introducción
The bread grabber spring in the Brentwood TS-292B can be removed and replaced with the help of this guide. The bread grabber spring is one of the primary components in the toaster that pops the toast when it's done.
When the toaster is used regularly or kept incorrectly, making the toaster inoperable, the spring may need to be replaced.
Furthermore, because the wire that works as the spring is difficult to bend into the precise shape, this repair may be challenging. This repair may require the use of large needle-nose pliers and a tweezer. This step-by-step instruction will show you how to get your toaster restored in working order.
Before beginning, make sure to power off your toaster completely and disconnect from any external power source.
Qué necesitas
Turn the toaster upside down.
Remove the five 6 mm screws with a Phillips #2 screwdriver.
