Saltar al contenido principal
Brentwood TS-292B Bread Grabber Spring Replacement
Qué necesitas
  1. Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: paso 1, imagen 1 de 2 Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: paso 1, imagen 2 de 2
    • Turn the toaster upside down.
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
  2. Brentwood TS-292B Bread Grabber Spring Replacement: paso 2, imagen 1 de 2 Brentwood TS-292B Bread Grabber Spring Replacement: paso 2, imagen 2 de 2
    • Grasp the plastic pull lever cover firmly and pull to remove it. This may require force.
    • Lift the cover upwards to remove it.
    • When removing the cover, do not damage the cable connector bundle that attaches the cover to the toaster.
  3. Brentwood TS-292B Bread Grabber Spring Replacement: paso 3, imagen 1 de 1
    • To detach the bundled cable connector, carefully pull it away from the circuit board.
  4. Brentwood TS-292B Bread Grabber Spring Replacement: paso 4, imagen 1 de 2 Brentwood TS-292B Bread Grabber Spring Replacement: paso 4, imagen 2 de 2
    • Pull the toaster lever down.
    • While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
    • Continuing to hold the toaster lever down, pinch the wires inward and pull up to carefully remove them from the toaster.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 355
