Introducción
This guide will show how to remove and replace the bread grabber of the Brentwood TS-292B.
Partes
No se requieren partes.
  1. Remove all 6mm screws with the Phillips #2 screwdriver from the bottom of the toaster
    • Remove all 6mm screws with the Phillips #2 screwdriver from the bottom of the toaster
  2. Pull lever tab away from the toaster with force (after pushing in the small tab located to the left)
    • Pull lever tab away from the toaster with force (after pushing in the small tab located to the left)
    • Remove toaster cover carefully
    • Detach the bundled cable connector by carefully pulling it away from the circuit board
    • Make sure to keep toasting lever down
    • Undo tabs with metal spudger on both sides
    • Pinch and carefully remove from toaster
Conclusión
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 27
Todo El Tiempo: 77
