Saltar al contenido principal
Braven BRV-X Front Speaker Panel Replacement
Qué necesitas
  1. Braven BRV-X Front Speaker Panel Replacement, Front Speaker Panel: paso 1, imagen 1 de 1
    • Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
  2. Braven BRV-X Front Speaker Panel Replacement: paso 2, imagen 1 de 1
    • Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
  3. Braven BRV-X Front Speaker Panel Replacement: paso 3, imagen 1 de 1
    • Gently remove the outer shell.
  4. Braven BRV-X Front Speaker Panel Replacement: paso 4, imagen 1 de 2 Braven BRV-X Front Speaker Panel Replacement: paso 4, imagen 2 de 2
    • Cut adhesive tape on both sides.
  5. Braven BRV-X Front Speaker Panel Replacement: paso 5, imagen 1 de 2 Braven BRV-X Front Speaker Panel Replacement: paso 5, imagen 2 de 2
    • Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
  6. Braven BRV-X Front Speaker Panel Replacement: paso 6, imagen 1 de 3 Braven BRV-X Front Speaker Panel Replacement: paso 6, imagen 2 de 3 Braven BRV-X Front Speaker Panel Replacement: paso 6, imagen 3 de 3
    • Pry open the glued inner shell using a spudger around all sides of the shell.
    • Don't use too much pressure as that could cause damage to the plastic.
  7. Braven BRV-X Front Speaker Panel Replacement: paso 7, imagen 1 de 2 Braven BRV-X Front Speaker Panel Replacement: paso 7, imagen 2 de 2
    • Remove ten 0.7 cm screws in the front plate using the 1.5 mm Hex screwdriver.
  8. Braven BRV-X Front Speaker Panel Replacement: paso 8, imagen 1 de 2 Braven BRV-X Front Speaker Panel Replacement: paso 8, imagen 2 de 2
    • Use a spudger to open the front speaker plate.
  9. Braven BRV-X Front Speaker Panel Replacement: paso 9, imagen 1 de 1
    • Remove three 1.0 cm screws from the battery unit.
    • It is recommended (but not required) to remove the battery.
  10. Braven BRV-X Front Speaker Panel Replacement: paso 10, imagen 1 de 2 Braven BRV-X Front Speaker Panel Replacement: paso 10, imagen 2 de 2
    • Disconnect the ribbon cable attached the main board.
  11. Braven BRV-X Front Speaker Panel Replacement: paso 11, imagen 1 de 3 Braven BRV-X Front Speaker Panel Replacement: paso 11, imagen 2 de 3 Braven BRV-X Front Speaker Panel Replacement: paso 11, imagen 3 de 3
    • Pry open the second plate holding in the speaker using a spudger around all sides.
    • It is recommended to use a spudger to remove the heavily glued areas between the plates before prying.
  12. Braven BRV-X Front Speaker Panel Replacement: paso 12, imagen 1 de 3 Braven BRV-X Front Speaker Panel Replacement: paso 12, imagen 2 de 3 Braven BRV-X Front Speaker Panel Replacement: paso 12, imagen 3 de 3
    • Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
    • Leave enough length on the wire to work with it afterwards.
    • Cut the 22 gauge wire attached in the corner.
    • Solder the new speaker plate during reassembly.
    • To properly solder and desolder connections, visit the How to Solder and Desolder Connections guide.
Conclusión
Trey Peterson
Miembro Desde 04/01/19
301 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G5, Harley Spring 2019 Miembro de IUPUI, Team S1-G5, Harley Spring 2019
IUPUI-HARLEY-S19S1G5
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 268
