Saltar al contenido principal
Braven BRV-1M Sub-woofer Cone Replacement
Qué necesitas
  1. Braven BRV-1M Sub-woofer Cone Replacement, Sub-woofer Cone: paso 1, imagen 1 de 1
    • To remove the outer rubber casing use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides, found on the bottom part of the device.
  2. Braven BRV-1M Sub-woofer Cone Replacement: paso 2, imagen 1 de 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Sub-woofer Cone Replacement: paso 3, imagen 1 de 1
    • To remove the hard inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the subwoofer on the top side of the device.
  4. Braven BRV-1M Sub-woofer Cone Replacement: paso 4, imagen 1 de 1
    • Carefully lift away the broken sub-woofer plate of the device. Replace with functioning sub-woofer plate.
Conclusión
Erik Oliva
Miembro Desde 02/14/18
607 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S2-G1, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 190
