Saltar al contenido principal
Braven BRV-1M Outer Casing Replacement
Qué necesitas
  1. Braven BRV-1M Outer Casing Replacement, Outer Casing: paso 1, imagen 1 de 1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Outer Casing Replacement: paso 2, imagen 1 de 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Outer Casing Replacement: paso 3, imagen 1 de 1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Outer Casing Replacement: paso 4, imagen 1 de 1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
Conclusión
Una persona más ha completado esta guía.
Erik Oliva
Miembro Desde 02/14/18
607 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S2-G1, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Miembros
6 Guías creadas
Un comentario
Where can I buy parts for this speaker? My rear charging door has broken off disabling the ruggedness. Be easier to buy versus build new piece.
Michael Harruff - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 635
