Saltar al contenido principal
Braun Shaver Model 7680 Battery Replacement
Qué necesitas
  1. Braun Shaver Model 7680 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Soldering is required to install this battery one or two batteries may be required verify how many you need before you order
  2. Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: paso 2, imagen 1 de 2 Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: paso 2, imagen 2 de 2
    • First pry the left side of the cover off, then pry the right side of the cover off before removing. Trying to pry the cover off from only one side will result in breaking the plastic tabs.
  3. Braun Shaver Model 7680 Battery Replacement, Remove side covers: paso 3, imagen 1 de 1
    • Pull the side covers off from the bottom, they hinge from the top and will come off freely once you rotate them up and away from the body starting at the bottom.
  4. Braun Shaver Model 7680 Battery Replacement, Remove screws on back: paso 4, imagen 1 de 2 Braun Shaver Model 7680 Battery Replacement, Remove screws on back: paso 4, imagen 2 de 2
    • You will need a T9 hex screw driver.
    • R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm
    • Replacing the batteries will not always repair the shaver, the circuit board may be bad, if the indicator lights on the circuit board do not light up when plugged in the circuit board is most likely bad, you should replace the entire circuit board and battery assembly.
Conclusión
19 personas más completaron esta guía.
mayer
Miembro Desde 01/04/10
688,033 Reputación
11 Guías creadas
Equipo
MacHale Enterprises Miembro de MacHale Enterprises
Business
1 Miembro
19 Guías creadas
8Guía Comentarios
Great tutorial. It was all I needed, since I wasn't sure how to get the case open. Thanks!
mikebailey - Contestar
Thanks for the tutorial! Mine had intermittent problem with the on/off switch and I was googling how to open the case. Easy and simple, bets razor I’ve had and not willing to change :D
Tero Kortetmäki - Contestar
Thanks for the tutorial… but it is a T8 Torx at least in the Model 7570. I just had to take out the recharchable batteries to get mine working properly again.
A Krueger - Contestar
Danke für die übersichtliche Anleitung, hat mir gut geholfen. Die wichtige Frage ist immer:
Wie geht ‘s Gehäuse auf. ?
Garofalo - Contestar
Thanks for the guide! Without knowing how to open the case, replacing the battery would have been a lost cause. In my case the batteries were tired. After replacing and recharging them the razor sounds young again and full of pep.
Stephen Spratley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 25
Ultimos 30 días: 101
Todo El Tiempo: 22,901
