Saltar al contenido principal
Braun Aromaster KF440 one-way valve Replacement
Qué necesitas
  1. Braun Aromaster KF440 one-way valve Replacement, Access the base: paso 1, imagen 1 de 1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 one-way valve Replacement, Remove the nut: paso 2, imagen 1 de 1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 one-way valve Replacement, Remove the cover: paso 3, imagen 1 de 1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
  4. Braun Aromaster KF440 one-way valve Replacement, Locate internal one-way valve: paso 4, imagen 1 de 1
    • Locate the one-way valve.
  5. Braun Aromaster KF440 one-way valve Replacement, Pull out valve: paso 5, imagen 1 de 1
    • Lift up on the one way valve to snap it out of place. (This shouldn't require much force).
  6. Braun Aromaster KF440 one-way valve Replacement, Push tube off the one-way valve: paso 6, imagen 1 de 1
    • Using the larger plastic opening tool, gently push the tubing off of the one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
  7. Braun Aromaster KF440 one-way valve Replacement, Lift valve: paso 7, imagen 1 de 1
    • Completely remove one-way valve from the inside of the coffee maker.
Conclusión
3 personas más completaron esta guía.
Dennis
Miembro Desde 10/20/14
315 Reputación
2 Guías creadas
Equipo
Baylor, Team 8-12, Williams Fall 2014 Miembro de Baylor, Team 8-12, Williams Fall 2014
BU-WILLIAMS-F14S8G12
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 36
Todo El Tiempo: 3,348
