Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Bracelet Clasp Replacement
Qué necesitas
    1. Bracelet Clasp Replacement, Bracelet clasp: paso 1, imagen 1 de 1
      • The clasp and metal ring (jump ring) need to be replaced.
      • Replace the jump ring first and then the clasp.
      • The correct size of a jump ring corresponds to the others on the bracelet.
      • Be sure the correct clasp for the bracelet is present.
      Pregunta a FixBot
      Agregar Comentario
    2. Bracelet Clasp Replacement: paso 2, imagen 1 de 2 Bracelet Clasp Replacement: paso 2, imagen 2 de 2
      • Use the needle-nose pliers to grasp the jump ring on its side, away from the break in the ring.
      Pregunta a FixBot
      Agregar Comentario
    3. Bracelet Clasp Replacement: paso 3, imagen 1 de 2 Bracelet Clasp Replacement: paso 3, imagen 2 de 2
      • Open the jump ring with the needle-nose pliers by holding one side of the ring with the pliers and the other side with your fingers.
      • Another set of needle-nose pliers can be used if the jump ring is too small to grasp.
      Pregunta a FixBot
      Agregar Comentario
    4. Bracelet Clasp Replacement: paso 4, imagen 1 de 2 Bracelet Clasp Replacement: paso 4, imagen 2 de 2
      • Attach the new, opened jump ring with the needle-nose pliers.
      • Here, there are two corresponding rings that the jump ring must be inserted through.
      Pregunta a FixBot
      Agregar Comentario
    5. Bracelet Clasp Replacement: paso 5, imagen 1 de 1
      • Hold the clasp in one hand and the pliers in the other.
      • Attach the new clasp to the opened jump ring being held by the needle-nose pliers by sliding the jump ring through all corresponding rings, including the clasp.
      Pregunta a FixBot
      Agregar Comentario
    6. Bracelet Clasp Replacement: paso 6, imagen 1 de 2 Bracelet Clasp Replacement: paso 6, imagen 2 de 2
      • Use the needle-nose pliers to close the jump ring by squeezing the two arms of the ring together.
      • Be sure to close the jump ring vertically between the two arms of the pliers. The jump ring should be parallel to the arms of the pliers.
      Pregunta a FixBot
      Agregar Comentario
    7. Bracelet Clasp Replacement: paso 7, imagen 1 de 1
      • Use the needle-nose pliers to tighten the jump ring, with the jump ring perpendicular to the two arms of the pliers.
      Pregunta a FixBot
      Agregar Comentario
    8. Bracelet Clasp Replacement: paso 8, imagen 1 de 2 Bracelet Clasp Replacement: paso 8, imagen 2 de 2
      • Test that the clasp and jump ring are properly attached by holding the bracelet from the clasp and suspending the rest of the bracelet.
      • If the bracelet successfully holds while suspended, the bracelet clasp and jump ring fix is successful.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
6 personas más completaron esta guía.
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 30
Ultimos 30 días: 117
Todo El Tiempo: 6,305
