Introducción
Use the guide to learn how to replace the motherboard for the Bowers and Wilkins T7 Bluetooth Speaker.
Qué necesitas
Herramienta utilizada en este paso:Tweezers$4.99
Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
While squeezing the internal locking mechanism, pull back the terminal.
Repeat this process for the second speaker.
Remove the leftmost 14mm screw with the J1 screwdriver tip.
Remove the rightmost 14mm screw with the J1 screwdriver tip.
With the screws removed, the motherboard is now loose.
Un comentario
OK, so now the motherboard is out. What can that acomplish? Where can you get a replacement? and where is there a circuit diagram to fault find??
