Saltar al contenido principal
Boss RC-1 Loop Station-Pedal Battery Replacement
Qué necesitas
  1. Boss RC-1 Loop Station-Pedal Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Push down on the pedal in order to relieve pressure on the thumbscrew.
  2. Boss RC-1 Loop Station-Pedal Battery Replacement: paso 2, imagen 1 de 1
    • Remove the thumb screw at the bottom of the device.
    • Loosening the thumb screw far enough will also allow the pedal to open.
  3. Boss RC-1 Loop Station-Pedal Battery Replacement: paso 3, imagen 1 de 2 Boss RC-1 Loop Station-Pedal Battery Replacement: paso 3, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the two screws that secure the pedal to the device.
  4. Boss RC-1 Loop Station-Pedal Battery Replacement: paso 4, imagen 1 de 1
    • Take the battery out of the device.
  5. Boss RC-1 Loop Station-Pedal Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect the snap chord from the battery.
  6. Boss RC-1 Loop Station-Pedal Battery Replacement: paso 6, imagen 1 de 1
    • Reassemble the device in the opposite order.
    • When tightening the thumbscrew back in the device, apply force to the pedal first (Do step 1 before step 2).
Conclusión
To check if the batter replacement was successful, plug in a guitar cable into the “Output A” jack. If the red light turns on below the “check” (top of the device), then the looper pedal is working.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 143
Todo El Tiempo: 5,343
