Saltar al contenido principal
Bose Wave Radio AWR1-1W Front Grill Replacement
Qué necesitas
  1. Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: paso 1, imagen 1 de 3 Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: paso 1, imagen 2 de 3 Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: paso 1, imagen 3 de 3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  2. Bose Wave Radio AWR1-1W Front Grill Replacement: paso 2, imagen 1 de 3 Bose Wave Radio AWR1-1W Front Grill Replacement: paso 2, imagen 2 de 3 Bose Wave Radio AWR1-1W Front Grill Replacement: paso 2, imagen 3 de 3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  3. Bose Wave Radio AWR1-1W Front Grill Replacement: paso 3, imagen 1 de 1
    • Lift the front grill away from the device.
Conclusión
To reattach the front panel, press it into the front of the device until it pops back into place.
Una persona más ha completado esta guía.
Cassie Harriman
Miembro Desde 04/18/17
1,033 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S15-G2, Banghart Spring 2017 Miembro de Cal Poly, Team S15-G2, Banghart Spring 2017
CPSU-BANGHART-S17S15G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 1,808
