Saltar al contenido principal
Bose Soundlink Revolve Subwoofer Replacement
Qué necesitas
  1. Bose Soundlink Revolve Subwoofer Replacement, Subwoofer: paso 1, imagen 1 de 1
    • Use a plastic opening tool or metal spudger to remove the rubber mount from the bottom of the speaker.
  2. Bose Soundlink Revolve Subwoofer Replacement: paso 2, imagen 1 de 1
    • Use a T10 screwdriver to remove the three 10 mm screws from the bottom of the speaker.
  3. Bose Soundlink Revolve Subwoofer Replacement: paso 3, imagen 1 de 1
    • Unhook the ribbon conector that connects the bottom cover to the body, then remove the bottom part of the speaker.
  4. Bose Soundlink Revolve Subwoofer Replacement: paso 4, imagen 1 de 1
    • Use a TR9 screwdriver to remove the screws from the top of the speaker, and then remove the top part of the speaker along with the motherboard.
  5. Bose Soundlink Revolve Subwoofer Replacement: paso 5, imagen 1 de 1
    • Slide the body of the speaker from the metal cover.
  6. Bose Soundlink Revolve Subwoofer Replacement: paso 6, imagen 1 de 1
    • Use a T10 screwdriver to remove the four 6 mm screws around the 2 speakers, and remove the speaker units from the body.
  7. Bose Soundlink Revolve Subwoofer Replacement: paso 7, imagen 1 de 1
    • Pull off the metal case from the speaker body.
  8. Bose Soundlink Revolve Subwoofer Replacement: paso 8, imagen 1 de 1
    • Remove the three 25.3mm screws from the bottom part of the speaker body with a T10 Torx screwdriver.
  9. Bose Soundlink Revolve Subwoofer Replacement: paso 9, imagen 1 de 1
    • Use a spudger to pry apart the glued section between the speaker panel and the device.
  10. Bose Soundlink Revolve Subwoofer Replacement: paso 10, imagen 1 de 1
    • Open the speaker panel, then unwind the three wires from the speaker.
Conclusión
8 personas más completaron esta guía.
Ruoyu Han
Miembro Desde 01/14/19
201 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G1, Wilson Spring 2019 Miembro de IUPUI, Team S1-G1, Wilson Spring 2019
IUPUI-WILSON-S19S1G1
3 Miembros
2 Guías creadas
6 comentarios
Is it possible to buy a replacement subwoofer? Mine has been dropped and it's only the bass elements that sound distorted, thank you
weedon2759 - Contestar
Subwoofer with sound distorted at my revolver speaker
david garcia Lopez - Contestar
I also cannot find a subwoofer replacement on the web. Do you know where I can buy one?
davlopest - Contestar
BOSE has a $75 option to refurbish the speaker, they do not sell the parts…..
chip - Contestar
Im glad to hear . I live in Puerto Rico and the authorized store wants to charge me $169.00 for a replacement. How do i go about this service . Thanks Bert
Humberto nieves -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 45
Ultimos 30 días: 236
Todo El Tiempo: 18,308
