Saltar al contenido principal
Bose Soundlink Revolve AUX/USB Port Replacement
Qué necesitas
  1. Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: paso 1, imagen 1 de 2 Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: paso 1, imagen 2 de 2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve AUX/USB Port Replacement: paso 2, imagen 1 de 3 Bose Soundlink Revolve AUX/USB Port Replacement: paso 2, imagen 2 de 3 Bose Soundlink Revolve AUX/USB Port Replacement: paso 2, imagen 3 de 3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve AUX/USB Port Replacement: paso 3, imagen 1 de 2 Bose Soundlink Revolve AUX/USB Port Replacement: paso 3, imagen 2 de 2
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve AUX/USB Port Replacement: paso 4, imagen 1 de 2 Bose Soundlink Revolve AUX/USB Port Replacement: paso 4, imagen 2 de 2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: paso 5, imagen 1 de 3 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: paso 5, imagen 2 de 3 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: paso 5, imagen 3 de 3
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
Conclusión
14 personas más completaron esta guía.
Brian Butner
Miembro Desde 09/27/17
861 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S6-G2, Remmell Fall 2017 Miembro de USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Miembros
4 Guías creadas
17 comentarios
Any idea where I can find the USB/Aux board for sale?
Chad - Contestar
Did you ever manage to find a place to buy it?
Steve Fantin -
You can buy a charging cradle for this device, maybe that helps..
adsf -
I am also looking for the usb port replacement part.
James Nowicki - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 69
Ultimos 30 días: 333
Todo El Tiempo: 31,909
