Saltar al contenido principal
Bose Soundlink Flex Battery Replacement
Qué necesitas
  1. Bose Soundlink Flex Battery Replacement, Grille: paso 1, imagen 1 de 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
  2. Bose Soundlink Flex Battery Replacement: paso 2, imagen 1 de 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
  3. Bose Soundlink Flex Battery Replacement: paso 3, imagen 1 de 2 Bose Soundlink Flex Battery Replacement: paso 3, imagen 2 de 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
  4. Bose Soundlink Flex Battery Replacement, Battery: paso 4, imagen 1 de 3 Bose Soundlink Flex Battery Replacement, Battery: paso 4, imagen 2 de 3 Bose Soundlink Flex Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
  5. Bose Soundlink Flex Battery Replacement: paso 5, imagen 1 de 3 Bose Soundlink Flex Battery Replacement: paso 5, imagen 2 de 3 Bose Soundlink Flex Battery Replacement: paso 5, imagen 3 de 3
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
  6. Bose Soundlink Flex Battery Replacement: paso 6, imagen 1 de 2 Bose Soundlink Flex Battery Replacement: paso 6, imagen 2 de 2
    • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
    • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
  7. Bose Soundlink Flex Battery Replacement: paso 7, imagen 1 de 3 Bose Soundlink Flex Battery Replacement: paso 7, imagen 2 de 3 Bose Soundlink Flex Battery Replacement: paso 7, imagen 3 de 3
    • Take the motherboard out and take note of the battery attached.
    • Remove the insulation and the solder from the wiring.
    • Be careful not to damage the motherboard. Doing so will create a slew of problems for the speaker.
    • Solder the wires of the new battery onto the motherboard.
    • Be cautious when adding the solder to not damage the motherboard or burn yourself.
Conclusión
Una persona más ha completado esta guía.
Kalvin Lee
Miembro Desde 03/19/24
435 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 Miembro de UMass Dartmouth, Team 4-1, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G1
Miembros de 3
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 63
Ultimos 30 días: 288
Todo El Tiempo: 2,033
