Saltar al contenido principal
Bose SoundTouch Portable Speaker Replacement
Qué necesitas
  1. Bose SoundTouch Portable Speaker Replacement, Speaker Battery: paso 1, imagen 1 de 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Speaker Replacement: paso 2, imagen 1 de 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Speaker Replacement, Grille: paso 4, imagen 1 de 1
    • Remove the two screws holding the speaker grille in place.
  5. Bose SoundTouch Portable Speaker Replacement: paso 5, imagen 1 de 1
    • Grip the sides of the device and push the speaker grille down and out.
  6. Bose SoundTouch Portable Speaker Replacement: paso 6, imagen 1 de 1
    • Gently release the ribbon from its connector and remove the grille.
  7. Bose SoundTouch Portable Speaker Replacement, Speakers: paso 7, imagen 1 de 1
    • There are four T-10 Torx screws for each speaker; remove all four screws for each speaker you are replacing.
  8. Bose SoundTouch Portable Speaker Replacement: paso 8, imagen 1 de 3 Bose SoundTouch Portable Speaker Replacement: paso 8, imagen 2 de 3 Bose SoundTouch Portable Speaker Replacement: paso 8, imagen 3 de 3
    • Using a plastic pry tool, carefully pry the speaker up.
    • With the bottom of the speaker exposed, unwind the wires from the connection tabs and replace the speaker.
Conclusión
Una persona más ha completado esta guía.
Chelsea Martin
Miembro Desde 02/20/17
697 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S1-G3, Leahy Spring 2017 Miembro de USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 1,829
