Saltar al contenido principal
Bose SoundTouch Portable Motherboard Replacement
Qué necesitas
  1. Bose SoundTouch Portable Motherboard Replacement, Speaker Battery: paso 1, imagen 1 de 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Motherboard Replacement: paso 2, imagen 1 de 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Motherboard Replacement, Metal Trim: paso 4, imagen 1 de 1
    • Remove the two screws using a torx screwdriver.
  5. Bose SoundTouch Portable Motherboard Replacement: paso 5, imagen 1 de 1
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  6. Bose SoundTouch Portable Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 Bose SoundTouch Portable Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
    • Remove four T-10 Torx screws; there are two on the front and two on the back.
  7. Bose SoundTouch Portable Motherboard Replacement: paso 7, imagen 1 de 3 Bose SoundTouch Portable Motherboard Replacement: paso 7, imagen 2 de 3 Bose SoundTouch Portable Motherboard Replacement: paso 7, imagen 3 de 3
    • Pinch and remove the connectors.
    • Use a flat tool to pry off the top piece.
  8. Bose SoundTouch Portable Motherboard Replacement: paso 8, imagen 1 de 3 Bose SoundTouch Portable Motherboard Replacement: paso 8, imagen 2 de 3 Bose SoundTouch Portable Motherboard Replacement: paso 8, imagen 3 de 3
    • Remove the four T-10 Torx screws holding the plastic cover in place.
    • Remove the one T-10 Torx screw that is holding the motherboard in place.
    • Pry off the motherboard.
Conclusión
2 personas más completaron esta guía.
Chelsea Martin
Miembro Desde 02/20/17
697 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S1-G3, Leahy Spring 2017 Miembro de USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 2,999
