Saltar al contenido principal
Bose SoundTouch 10 Bass Port Replacement
Qué necesitas
  1. Bose SoundTouch 10 Bass Port Replacement, Front Panel: paso 1, imagen 1 de 1
    • Turn the speaker over so that the rubber strips along the bottom are facing you.
    • Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
  2. Bose SoundTouch 10 Bass Port Replacement: paso 2, imagen 1 de 1
    • Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
  3. Bose SoundTouch 10 Bass Port Replacement: paso 3, imagen 1 de 2 Bose SoundTouch 10 Bass Port Replacement: paso 3, imagen 2 de 2
    • Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
    • Lift the panel away to reveal the speaker head.
  4. Bose SoundTouch 10 Bass Port Replacement, Back panel: paso 4, imagen 1 de 1
    • Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
  5. Bose SoundTouch 10 Bass Port Replacement: paso 5, imagen 1 de 1
    • Flip the speaker onto its back.
    • Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
  6. Bose SoundTouch 10 Bass Port Replacement: paso 6, imagen 1 de 2 Bose SoundTouch 10 Bass Port Replacement: paso 6, imagen 2 de 2
    • Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
    • If the panel does not come free easily, a heat gun may be needed to weaken the adhesive.
    • Once the panel has been disconnected, it should fall open revealing the motherboard.
  7. Bose SoundTouch 10 Bass Port Replacement: paso 7, imagen 1 de 2 Bose SoundTouch 10 Bass Port Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use ESD Safe Tweezers (Blunt Nose) to pull out the wire ribbon at the end of the motherboard.
  8. Bose SoundTouch 10 Bass Port Replacement: paso 8, imagen 1 de 2 Bose SoundTouch 10 Bass Port Replacement: paso 8, imagen 2 de 2
    • The motherboard contains capacitors (shown as cylinders in the upper right of the picture) which can hold a charge even when the speaker is powered off. Do not touch them as doing so may result in a shock.
    • Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
  9. Bose SoundTouch 10 Bass Port Replacement, Bass Port: paso 9, imagen 1 de 1
    • Use a #0 Phillips screwdriver to remove each of the two 11mm screws attached to the bass port.
  10. Bose SoundTouch 10 Bass Port Replacement: paso 10, imagen 1 de 1
    • Lift the bass port away from the motherboard.
Conclusión
2 personas más completaron esta guía.
James Asbury
Miembro Desde 04/10/17
898 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S13-G1, Forte Spring 2017 Miembro de Cal Poly, Team S13-G1, Forte Spring 2017
CPSU-FORTE-S17S13G1
4 Miembros
5 Guías creadas
Un comentario
I whant purchase capacitor 330
35v
Chandan Kumar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 3,819
