Introducción
The back panel houses the motherboard for the speaker. It needs to be removed in order to replace the motherboard as well as several other components.
The motherboard in this guide contains capacitors which can hold a charge even when the speaker is powered off. Do not touch the as it may result in a shock.
Qué necesitas
Turn the speaker over so that the rubber strips along the bottom are facing you.
Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
4 personas más completaron esta guía.
