Introducción
If you need to replace the speakers of your Bose SoundLink Mini, follow this guide. The speakers are the main components in this device, and after time or bad wiring connection they may become unresponsive and need to be replaced. They are located deep within the body of the device and a several other parts will be needed to be removed before the two speakers can be accessed. Make sure you have all the necessary tools and follow all prerequisite guides in order to replace the two speaker parts.
Qué necesitas
Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
Remove the sponge (save for later replacement) and gently flip the black tab 90 degrees to release the connectors grip on the ribbon cable. Remove the ribbon cable from the connector.
16 personas más completaron esta guía.
16 comentarios
This is great! Well done! Thank you. I dropped mine and there's not any sound now. What would you think happened and where should i start?
Perhaps open it up and then use a multimeter or some other speakers to see if you're getting any output from the amplifier? Sometimes the speaker drivers are damaged by dropping.
Do you know the part number for the speaker or where to buy it ? After a trip to the beach I now have a cracking sound in one of the speakers.
Thanks for the help
Do you know if the the other speakers were passive radiators or powered subwoofers? Bose claims that the are subwoofers but I'm skeptical
