Saltar al contenido principal
Bose SoundLink Mini Front/Back Protective Grille Replacement
Qué necesitas
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: paso 1, imagen 1 de 1
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: paso 2, imagen 1 de 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: paso 2, imagen 2 de 2
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: paso 3, imagen 1 de 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: paso 3, imagen 2 de 2
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: paso 4, imagen 1 de 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: paso 4, imagen 2 de 2
    • Repeat steps to remove the back grille.
Conclusión
9 personas más completaron esta guía.
Jordan Smith
Miembro Desde 10/01/15
880 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 1-23, Maness Fall 2015 Miembro de Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Miembros
21 Guías creadas
6 comentarios
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - Contestar
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - Contestar
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - Contestar
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 25
Ultimos 30 días: 91
Todo El Tiempo: 11,783
