Introducción
Use this guide to replace the front or back mesh grilles. Make sure you have the required tools. The first time you remove a grille might be a little difficult due to some glue holding it in place. Be careful when removing, as the grille may bend easily.
Herramientas
Partes
No se especificaron partes.
Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
8 personas más completaron esta guía.
4 comentarios
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
