Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The battery is located on the bottom of the speaker underneath a rubber protective cover. Use this guide to replace a faulty battery in your SoundLink Mini. Check what model battery your your SoundLink Mini has before purchasing a replacement.
  1. Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
    • Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
  2. While holding the cover back, pull straight up on the battery to remove it. While holding the cover back, pull straight up on the battery to remove it.
    • While holding the cover back, pull straight up on the battery to remove it.
Conclusión
67 personas más completaron esta guía.
Brant Jordan
Miembro Desde 01/10/15
1,434 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 1-23, Maness Fall 2015 Miembro de Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Miembros
15 Guías creadas
Where can one purchase this battery, shipped to a US address?
Bob Smith - Contestar
Were can we I get the battry to order ... need it badly pls m.
kaiserteach -
I need the battry for soundlink mini ... pls were can I get it
kaiserteach -
Where can we get the battery ordered?
Marian D - Contestar
Anyone know where to get the battery?
aboveebegun - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 79
Ultimos 7 días: 644
Ultimos 30 días: 2,828
Todo El Tiempo: 191,167
