Introducción
If you are experiencing any audio issues with the lower frequency sounds (the bass) such as distortion, muffling, quietness, or total absence of sound, you may need to replace your bass speaker.
Qué necesitas
Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
Gently peel back the adhesive padding on either side of the inner back panel.
Remove the four 12.5 mm screws using a Philips #2 screwdriver.
You will now be able to remove the bass speaker.
5 personas más completaron esta guía.
2 comentarios
Where can I buy this bass speaker (Bose SoundLink III)?
