Qué necesitas
Empiece tirando de los bordes exteriores de la sección de goma de la parte inferior del altavoz.
enga en cuenta que no se separará completamente del altavoz.
Para volver a ensamblar su aparato, siga las instrucciones en el orden inverso.
9 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Carlos López (España - Spain) nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
4 comentarios
Please be advised that the Bose support website has a firmware update that fixes some battery issues. I took my dead - non-charging Soundlink Color II apart and then found the website and fixed the issue with the firmware update! The update website is located @ http://btu.bose.com
Beware that, after the battery gets undervolted (like 2.4V), the device does not seem to accept an externally charged battery and continues to act dead, until it finds some form of comfort over its USB input. Not from a dumb 5V power supply, but from an USB charger or PC supporting some level of power delivery extension, and an appropriately wired lead.
Please list type of battery and where to find it it took me a while to find it
Guide was good, the battery pcb i found in my unit was a bit different and had metal strips soldered to the board and welded to the battery.
