Introducción
If the steps are followed properly, you can expect to learn how to replace speakers that are not working correctly. You will learn how to remove the front face containing the speakers, how to dissect the screws and wires, and how to connect wires to the new speakers. The proper knowledge of how to use a soldering iron is required when dealing with this component.
Qué necesitas
Remove six 10 mm length screws from the bottom panel of the SoundDock.XT using a #1 Phillips screwdriver.
Lift back cover to reveal the speakers. This is what you should be able to see once you have completed the above steps.
To reassemble your device, follow these instructions in reverse order. With proper execution of these steps, you will be able to replace your speakers and enjoy the sound of your SoundDock XT.
3 personas más completaron esta guía.
4 comentarios
Hello what size are the speakers in this? Looking to buy some replacements
Could you help me with the part number please?
Thanks a lot !
Greetings from Mexico !
Please send video
Please send video bose SoundDock xt how to open
