Saltar al contenido principal
Bose SoundDock Portable v2 IR Receiver Replacement
Qué necesitas
  1. Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: paso 1, imagen 1 de 3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: paso 1, imagen 2 de 3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: paso 1, imagen 3 de 3
    • Gently pry the front mesh cover off of the sound dock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart.
  2. Bose SoundDock Portable v2 IR Receiver Replacement: paso 2, imagen 1 de 1
    • Using a T15 torx screwdriver, remove the 8mm screw holding the IR sensor to the speaker system.
  3. Bose SoundDock Portable v2 IR Receiver Replacement: paso 3, imagen 1 de 1
    • Using tweezers or your fingers, gently remove the ribbon cable connecting the IR sensor to the system.
Conclusión
2 personas más completaron esta guía.
Evan Low
Miembro Desde 04/14/15
551 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 4-1, Maness Spring 2015 Miembro de Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Miembros
5 Guías creadas
Un comentario
Hi my sounddock blocked suddenly and the green led always on. Do you now something about please... :(
jose - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 6,746
