Saltar al contenido principal
Bose Solo 5 Sound Bar Speaker Replacement
Qué necesitas
  1. Bose Solo 5 Sound Bar Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Lay Bose Solo 5 on its top side with the speakers facing away from you.
  2. Bose Solo 5 Sound Bar Speaker Replacement: paso 2, imagen 1 de 2 Bose Solo 5 Sound Bar Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the two screws located at the outer edge of the backside with a Phillips head screwdriver.
  3. Bose Solo 5 Sound Bar Speaker Replacement: paso 3, imagen 1 de 1
    • Lay the speaker on its backside with the speakers facing up. Wedge the plastic opening tool into the crack where the protective wire screen meets the housing. Pry apart until you create enough room for your fingers.
  4. Bose Solo 5 Sound Bar Speaker Replacement: paso 4, imagen 1 de 2 Bose Solo 5 Sound Bar Speaker Replacement: paso 4, imagen 2 de 2
    • Pull the screen gently away from the housing to reveal the two speakers with your fingers.
  5. Bose Solo 5 Sound Bar Speaker Replacement: paso 5, imagen 1 de 3 Bose Solo 5 Sound Bar Speaker Replacement: paso 5, imagen 2 de 3 Bose Solo 5 Sound Bar Speaker Replacement: paso 5, imagen 3 de 3
    • Remove the 4 screws in each corner of the speaker to remove it from the housing.
  6. Bose Solo 5 Sound Bar Speaker Replacement: paso 6, imagen 1 de 2 Bose Solo 5 Sound Bar Speaker Replacement: paso 6, imagen 2 de 2
    • Peel back the styrofoam on the speaker & disconnect the yellow & brown wires by sliding them off the receptor.
Conclusión
3 personas más completaron esta guía.
Chase Cooper
Miembro Desde 10/09/18
220 Reputación
1 Guía escrita
Un comentario
Well opening the case affect its original sound tuning or will it affect the performance ?
Saket Adhau - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 38
Ultimos 30 días: 176
Todo El Tiempo: 12,839
