Saltar al contenido principal
Bose Solo 5 Sound Bar Remote Batteries Replacement
  1. Bose Solo 5 Sound Bar Remote Batteries Replacement, Remote Batteries: paso 1, imagen 1 de 3 Bose Solo 5 Sound Bar Remote Batteries Replacement, Remote Batteries: paso 1, imagen 2 de 3 Bose Solo 5 Sound Bar Remote Batteries Replacement, Remote Batteries: paso 1, imagen 3 de 3
    • Open the battery compartment cover on the back of the remote by applying pressure with fingers and sliding downward.
  2. Bose Solo 5 Sound Bar Remote Batteries Replacement: paso 2, imagen 1 de 1
    • Remove both AA batteries carefully.
  3. Bose Solo 5 Sound Bar Remote Batteries Replacement: paso 3, imagen 1 de 1
    • Look for any battery acid corrosion in the wells and clean with a cotton swab or a dull pointed tool to remove the residue.
    • Insert two AA (IEC-LR6) 1.5V batteries or the equivalent.
    • Match the + and – symbols on the batteries with + and – markings inside the compartment.
  4. Bose Solo 5 Sound Bar Remote Batteries Replacement: paso 4, imagen 1 de 3 Bose Solo 5 Sound Bar Remote Batteries Replacement: paso 4, imagen 2 de 3 Bose Solo 5 Sound Bar Remote Batteries Replacement: paso 4, imagen 3 de 3
    • To reassemble your device, place the cover back over the batteries by lining up the teeth and sliding upward until you hear a click.
Conclusión
We hope this guide was useful to you! Replacing your Bose Solo 5 Soundbar remote batteries should be quick and easy!
Una persona más ha completado esta guía.
Emma
Miembro Desde 10/05/18
500 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 35
Todo El Tiempo: 4,557
